Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 52
Thread: Lisp Legend
    2017-10
    Florida
    26
    Default Lisp Legend
    I have a lisp that creates a legend based on active blocks in the drawing, it uses an external text file to check block names and populates the legend. I need to modify the lisp. We are transitioning from using blocks to description keys. Is there a way to do something like tblnext with cogo points based on the point style?
    for example this line would cycle through the blocks
     (setq bname (cdr (assoc 2 (setq blist (tblnext "BLOCK" T)))))
    the lisp then checks bname against the external file and if it appears in the list it adds the symbol and text to the legend.
    I need to do the same but based on the point style of the cogo point.
    (setq ptStyle (VLAX-GET c3ddoc 'pointstyle))
    I was thinking that this might be a start.
    2010-06
    962
    2
    Default Re: Lisp Legend
    Hi,
    Here is a good start for you to continue with.
    (defun CollectBlockNamesFromTextFile (/ textfile openFile blockName BlockNames)
      (if (and (setq textfile (getfiled "Select the text file that has the block names." "" "txt" 16))
               (setq openFile (open textfile "r"))
        (progn
          (while (setq blockName (read-line openFile))
               (setq BlockNames (cons blockName BlockNames))
             (close openFile)
      BlockNames
    (if (setq lst (CollectBlockNamesFromTextFile))
      (while (setq obj (tblnext "BLOCK" (not obj)))
        (if (member (cdr (assoc 2 obj)) lst)
           ;; do your stuff here	;;
    2003-07
    561
    As you want a legend for cogo points you need to inspect the actual points in the dwg, we have around 200+ point styles as these match our field coding, a typical dwg uses a very small amount of these.
    So you need to go through the points I am not sure if there is a "style in use" for the point styles which would be the quickest way. It may be a property of the point style will try to find some time to look .
    (setq pdks (vlax-get-property *AeccDoc* 'pointdescriptionkeysets))
    (setq ptstys (vlax-get-property *AeccDoc* 'PointStyles))
    (setq ptlabstys (vlax-get-property *AeccDoc* 'PointLabelStyles))
    2003-07
    561
    Ok had a quick look
    Primary point group : Points
    Point Number : 5652
    Northing : 5770864.717m
    Easting : 284671.443m
    Point Elevation : 62.356m
    Raw Description : TR
    Full Description : TREE
    Description Format : TREE
    Style : TR
    Point Label Style : None
    Survey Point : False
    So the point has a description point style of TR which has a block for a tree what you want for your legend. I think your stuck with going through the points and make a list of codes. Its a bit of pain as you have to keep looking into the styles for the block. I would go the path of a text file with stylenane blockname per line much easier.
    Not a quick to code.
    2017-10
    Florida
    26
    Thanks everyone for the input. I'm going to try your suggestions and report back.
    2017-10
    Florida
    26
    How would one search the point styles? I know how to select a point and "Get" the pointstyle from it. Would I select all the points in the drawing with the following?
    (setq selPnts (ssget "x" '((0 . "AECC_COGO_POINT"))))
    How would I get the point style from the points after selecting them and them cycle through? Would creating a list of the points work? then comparing the point style to the block name list?
    kind of thinking out loud.
    2010-06
    962
    Quote Originally Posted by _brxdvs View Post
    Hi,
    Copy and paste the following codes into your AutoCAD command line then you would prompt to select an entity, so select a point to see the related DXF codes and from that list you should be able to see the style name within that list and it is may start with 2 or 3 not sure because I have not used Civil3D at all before.
    (if (setq e (car (entsel "\nSelect point object :")))
      (foreach x (entget e) (print x))
    After selecting the point object hit F2 to enlarge the Window Text screen of your AutoCAD and to see the DXF codes.
    2017-10
    Florida
    26
    Tharwat
    this is what I got from AutoCAD
    Command:
    (_>   (foreach x (entget e) (print x))
    (_>   )
    (-1 . <Entity name: 7ff7646304a0>)
    (0 . "INSERT")
    (330 . <Entity name: 7ff7646551f0>)
    (5 . "46A32")
    (100 . "AcDbEntity")
    (67 . 0)
    (410 . "Model")
    (8 . "U-VLT")
    (100 . "AcDbBlockReference")
    (2 . "VLT")
    (10 22840.7 48241.6 0.0)
    (41 . 20.0)
    (42 . 20.0)
    (43 . 20.0)
    (50 . 0.0)
    (70 . 0)
    (71 . 0)
    (44 . 0.0)
    (45 . 0.0)
    (210 0.0 0.0 1.0) (210 0.0 0.0 1.0)
    This looks like the thing I am looking for
    (2 . "VLT")
    2010-06
    962
    That is a block reference or point object?
    If its a block reference as it is clear from the return of the codes then just use these codes to select all block references with the same name:
    (setq ss (ssget "_X" '((0 . "INSERT")(2 . "VLT"))))
    2017-10
    Florida
    26
    I selected a cogo point. It has description keys applied. in this case it is a vault (VLT). It appears that (2 . "VLT") is the point style.
  1. Replies: 5
    Last Post: 2016-01-10, 04:44 PM
  2. Replies: 7
    Last Post: 2014-05-15, 03:00 PM
  3. Tags in Legend Views / Tag legend components
    Last Post: 2012-11-14, 07:08 AM
  4. Replies: 3
    Last Post: 2012-05-07, 08:16 PM
  5. Copy / Paste from Legend to Legend
    By antman in forum Revit Architecture - General
    Last Post: 2011-04-12, 03:22 PM
Tags for this Thread
