Thread: text mirroring
    2017-12
    2
    Default text mirroring
    I have two drawings that mirror all of the text. can't find the setting to fix it.
    Earth
    9,805
    Default Re: text mirroring
    What do you mean they "mirror all of the text"?
    Do you mean when you create a new TEXT object, a second mirrored copy of it is created at the same time?
    Or do you mean that any text you create is mirrored by default?
    Or something else?
    Can you attach the DWG file (or a stripped down version of it)?
    R.K. McSwain | CAD Panacea |
    2017-12
    2
    any text is automatically reversed.
    2014-08
    448
    Try the MIRRTEXT VARIABLE
    2005-06
    in the upper right corner
    3,507
    Quote Originally Posted by fjdllc761057 View Post
    Quote Originally Posted by remi678731 View Post
    Sounds like text (mtext?) is being "created" in reverse, MIRRTEXT only applies to text when you mirror it, weather to mirror it or not.
    If I had to guess, I would think your UCS is not set correctly, like it got flipped somehow and so you're drawing in reverse.
    (see image)
    Try setting it to World (WCS); command: UCS > World
    And then try creating text.
  1. Text in mirroring xref
    Last Post: 2014-09-07, 10:09 AM
  2. Mirroring Xref text
    By Rico in forum AutoCAD General
    Last Post: 2010-09-23, 04:33 PM
  3. Mirroring and text justification
    By tiffany.amorgan in forum Dynamic Blocks - Technical
    Last Post: 2008-01-16, 04:16 PM
  4. Mirroring Text
    By Tyveka in forum Revit Architecture - General
    Last Post: 2007-06-05, 04:47 PM
  5. Mirroring Text
    By relysoft in forum AutoCAD General
    Last Post: 2005-03-29, 02:28 PM
