Results 1 to 6 of 6
Thread: Block @ PIs
    2009-11
    Raleigh, NC
    701
    Default Block @ PIs
    Is there away to make a block be inserted dynamically with any PI in Parcels. When generating residential subdivision drawings I have to have a very simple block to clearly show where line and curve labels begin and end. Its actually right much work inserting these at every PI and thats not even accounting for the constant revising of the lot layouts.
    Earth
    9,756
    Default Re: Block @ PIs
    Ah, I wrote a routine to do this years ago. We drew our parcels with lines and arcs, then ran this routine to generate the blocks for the endpoints.
    Of course it checked for duplicates and this was somewhat of a check to ensure geometry endpoints were coincident. (after all of this, we generated the parcels)
    You want them to be dynamic to the parcel entities though, right?
    R.K. McSwain | CAD Panacea |
    2009-11
    Raleigh, NC
    701
    Yes, Sorry for the delayed reply. One of those end of day questions and never remember until now seeing a revised site plan with property markers floating all over the page.
    2015-10
    Central New Jersey
    421
    You could make the blocks part of your current segment labels to be inserted at the 'start' and 'end' locations. Or, make them their own label style.
    Alignment/rotation may be an issue.
    2009-11
    Raleigh, NC
    701
    Quote Originally Posted by MMccall View Post
    I like the idea. I have created many label styles but nothing of that nature. Could you tell me where to start in the label style composer?
    2015-10
    Central New Jersey
    421
    In the label style composer on the layout tab there is a pull down list or 5 component types you can add to a label style. 'Block' is one of those components.
    Anchor points available for components are 'Start, Middle, End and Label Location'. You'll use Start and End for the blocks.
  1. Replies: 1
    Last Post: 2017-01-15, 12:22 AM
  2. How to change dynamic block attribute default values based on block selected?
    By zeirz109180 in forum Dynamic Blocks - Technical
    Last Post: 2013-12-13, 02:20 PM
  3. 2013: Can't find user block in block list while creating a multi-leader style
    By rsturgeon502669 in forum AutoCAD Annotation
    Last Post: 2013-07-08, 07:05 AM
  4. Replies: 2
    Last Post: 2012-06-06, 12:28 PM
  5. Highlight Last Opened Block in Block Editor Block List
    Last Post: 2008-10-11, 09:03 PM
