Coolmo
I'll never be able to "unteach" the double click method so is there any way I can make Civil 3D launch properly from double clicking in Explorer?
Short answer is, No - even when you modify the OpenLaunch REG_SZ (see below) to be the exact same as your desired Application Icon's Target Path... Everything is loaded properly in terms of Civil 3D functionality, but the taskbar icon still depicts the red AutoCAD icon. Grrr
If you're not able to have them replaced, consider this numpty repellent:
First, save this to a .BAT file on their C:\ drive... For the purposes of this example, I'll use C:\CAD\FOO.bat (you can always use something more elegant, like PowerShell, Visual Studio, etc this is just a quick example):
@echo off
title Stop Double-Clicking DWGs, Open In Civil 3D Instead
color 4E
echo/
echo/
echo ********************************************************************
echo * *
echo * Stop Double-Clicking DWGs! *
echo * *
echo * Open In Civil 3D Instead *
echo * *
echo/
echo/
::timeout 5 > NUL
pause
Next, using RegEdit.exe, navigate to this key and export it as a backup for CYA:
Computer\HKEY_CURRENT_USER\Software\Autodesk\DWGCommon\shellex\Apps\{F29F85E0-4FF9-1068-AB91-08002B27B3D9}:AutoCAD
Note - The GUID may be different on your machines
Lastly, change the value of OpenLaunch REG_SZ (and maybe PrintLaunch?) to be:
... Now when they double click a DWG in File Explorer, they get this:
Happy numpty hunting!
Cheers
