Results 1 to 9 of 9
Thread: LAYER AND MODEL SPACE COLORS NOT SHOWING PROPERLY
    100 Club gisdude's Avatar
    2005-10
    104
    Default LAYER AND MODEL SPACE COLORS NOT SHOWING PROPERLY
    Hi all,
    I'm having a problem with one drawing out of a dozen. I have all my colors set to "by layer" however all my text/linework are MOSTLY grey scaled out. I have some entities on my "ADD" LAYER which will show the color properly - in this case red. But, some lines will be greyed out and I'll have to double click them to show red, but once I de-select, they'll go back to grey.
    It's like I have hit some setting/variable and I don't know how I did it because the other 10 drawings are fine. I've done recover, purge, audit, overkill. I've restarted the pc.
    Thx for any help
    6,409
    Default Re: LAYER AND MODEL SPACE COLORS NOT SHOWING PROPERLY
    Post the dwg so we can look at it.
    LinkedIn
    in the upper right corner
    3,507
    Yes, posting a sample drawing would be best to help.
    It could be a few things, viewport overrides, "xrefoverride" set to 1, plotstyle maybe?
    would be good to see what you're seeing.
    9,804
    Is this when viewing the drawing in a layout? If so, you may have "Display Plot Styles" checked on in the PageSetup.
    2005-10
    104
    Well, I'm in Model Space...so this SHOULDN'T be an issue.
    For the time being, I've just re-did the linework and text - it was only a couple of things, but why only the 1 file?
    Thanks for the help.
    2014-08
    447
    Hi
    Several years ago about 2007 I think I had an entire dwg go grey scale tried everything I could think of sent it to a couple different CAD support techs no one ever figured out what happened. Lucky we had a back up that was just fine.
    2005-10
    104
    When you look at the “STYLIZATION” option, it was ON. But when you turn off, voila!.
    Command: MAPDISPLAYMANAGER
    Display Manager [?/Load/Update/Stylization/eXit] <eXit> :U
    Updating...
    Updating...
    Display Manager [?/Load/Update/Stylization/eXit] <eXit> :S
    Stylization [On/oFf] <On> : F
    Display Manager [?/Load/Update/Stylization/eXit] <eXit> :Regenerating model.
    So frustrating...but finally.
    2015-11
    4
    Thank you, this brought back the colors for me in Modelspace. I was updating some old blocks and I went into a grayscale on certain items when I brought in other drawings. Thank you, gisdude, for posting a solution.
    2015-11
    4
    Thank you, gisdude! Great work!
  1. Replies: 1
    Last Post: 2017-03-01, 01:51 PM
  2. Model space layer freeze
    Last Post: 2016-10-26, 03:50 PM
  3. Layer Frozen/Off Status in Model Space/Layout Space
    Last Post: 2013-01-17, 04:29 AM
  4. Freeze layer in Model space viewport
    By matthew.ozor in forum AutoCAD General
    Last Post: 2010-03-19, 10:14 PM
  5. Duct Labels not showing in Model Space
    By solarsupplies in forum AMEP General
    Last Post: 2010-02-19, 04:28 PM
