Thread: Edit Wall Sweep Profile?
    All AUGI, all the time BillyGrey's Avatar
    2004-04
    in a calm assertive state
    638
    Default Edit Wall Sweep Profile?
    This image shows a hosted wall sweep at wall base.
    The window sill sits 6" below the top of sweep.
    Is there a way to edit profile the way we can walls?
    TIA
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Edit Wall Sweep Profile?
    Try using the cut geometry tool, or try cutting and pasting the window back into the wall.
    Sometimes that'll get the sweep to cut.
    2004-04
    638
    Thanks Andrew.
    I was applying that sweep to the wall...
    What I ended up doing was creating a compound wall by adding the
    sweep profile to the wall in the wall properties dialog,
    and setting the "cuttable" option to on.
    That did the trick.
    Thanks
  1. Solid sweep profile is not visible in edit mode
    By hkadani in forum Revit Structure - General
    Last Post: 2008-10-20, 08:23 PM
  2. Wall sweep on edited elevation profile
    By AUGI Strangelove in forum Revit Architecture - General
    Last Post: 2008-06-26, 02:32 PM
  3. Wall Sweep Cut Profile Help...
    By twiceroadsfool in forum Revit Architecture - General
    Last Post: 2006-12-08, 01:25 PM
  4. Parapet Sweep w/ Edited Wall Profile
    By bpayne in forum Revit Architecture - General
    Last Post: 2005-04-22, 08:08 PM
  5. Wall Sweep Profile
    By Thomas Cummings in forum Revit Architecture - General
    Last Post: 2004-11-28, 10:48 PM
