Results 1 to 10 of 15
Thread: Herringbone Hatch Pattern
    2018-03
    7
    Default Herringbone Hatch Pattern
    Hi All;
    i have been trying for many evenings now without much luck to do do a 100mm x 600mm herringbone hatch pattern with 2mm joints. i will be gratefull is anyone can put me on the right track.
    Many thanks,
    Sam
    I could stop if I wanted to hugh.69031's Avatar
    2016-01
    Melbourne, Australia
    357
    Default Re: Herringbone Hatch Pattern
    From HatchKit's Brick&Tile wizard, try:
    ; Written by HatchKit for AutoCAD
    ; HatchKit for AutoCAD (c)1990-2017 Cadro Pty Ltd
    ; www.hatchkit.com.au/
    ;-Date : 2018-03-09
    ;-Time : 08:46:47
    ;-HatchKit Version : 3.1.10.2717
    ;-HatchKit Output Filetype : AutoCAD format
    *herringbone,LEFT-HAND 600mmx100mm weave=1/1
    89.9904808475,0,0,1213.99832184,10.2016944929,100,-11938.0001661
    0.0095191525147,0,100,1213.99832184,-10.2016944929,600,-11438.0001661
    -90.0095191525,600,100,1213.99832184,10.2016944929,100,-11938.0001661
    180.009519153,600,0,1213.99832184,-10.2016944929,600,-11438.0001661
    89.9904808475,-102,-500,1213.99832184,10.2016944929,600,-11438.0001661
    0.0095191525147,-102,100,1213.99832184,-10.2016944929,100,-11938.0001661
    -90.0095191525,-2,100,1213.99832184,10.2016944929,600,-11438.0001661
    180.009519153,-2,-500,1213.99832184,-10.2016944929,100,-11938.0001661
    hth,
    Hugh Adamson
    www.hatchkit.com.au
    2018-03
    7
    Thank you Hugh, that's brilliant, works a treat.
    regards
    Sam
    *buttedhb,Butted Herringbone parquetry
    0, 0,0, .1,.1, .6,-.4
    90, .5,-.6, -.1,.1, .6,-.4
    2018-03
    7
    Hi Hugh,
    I hope you don't mind me asking, any chance you could do a 100x500mm Chevron hatch pattern(trapezoidal 45 degree angle pieces) again with 2mm joints?
    best regards,
    Sam
    2016-01
    357
    Quote Originally Posted by sam woodward View Post
    Hi Hugh,
    best regards,
    Sam
    sure:
    ; Written by HatchKit for Revit
    ; HatchKit for Revit (c)1990-2017 Cadro Pty Ltd
    ;-Date : 2018-03-14
    ;-Time : 10:36:10
    ;-HatchKit Version : 3.1.10.2733
    ;-HatchKit Output Filetype : Revit with HatchKit Add-In
    ;%VERSION=3.0
    ;%UNITS=MM
    *Brick1,LEFT-HAND 500mmx100mm weave=1/1
    ;%TYPE=MODEL
    135.028547969,0,0,1011.99588833,-8.50423412125,500,-11542.0014948
    44.9714520305,1.4142,-142.84,1011.99588833,8.50423412125,500,-11542.0014948
    135.028547969,-70.711,-70.711,1011.99588833,-8.50423412125,500,-11542.0014948
    44.9714520305,-69.296,-72.125,1011.99588833,8.50423412125,500,-11542.0014948
    135.028547969,354.97,210.72,1011.99588833,-8.50423412125,100,-11942.0014948
    44.9714520305,-70.711,-70.711,1011.99588833,8.50423412125,100,-11942.0014948
    135.028547969,1.4142,-142.84,1011.99588833,-8.50423412125,100,-11942.0014948
    44.9714520305,-424.26,282.84,1011.99588833,8.50423412125,100,-11942.0014948
    - required a rotation before saving that pattern.
    hth,
    Hugh
    2018-03
    7
    Morning Hugh
    thank you for doing this, each tile is still a rectangle with 90 Degrees, what i needed was a 500x100 tile that is trapezoidal with internal angles 45,and 135 so that they form a chevron pattern when they are butted together.
    many thanks,
    Sam
    2016-01
    357
    Morning Hugh
    many thanks,
    Sam
    My mistake, misread. While I'm 90% sure of your intent, this gets away from the HatchKit Brick and Tile Wizard into pattern editing so could you please provide a sketch.
    thanks,
    Hugh
    2015-12
    2,095
    I'd be cautious about trying to use hatches for representation of physically dimensioned objects like tiles, blocks, or bricks. Like line types they're symbolic in purpose so there's no guarantee of proper sizes and positions.
    You might consider using an array of dynamic blocks for this.
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    2018-03
    7
    HI hUGH
    I did a sketch but didn't know how to attach the pdf file, i have attached a photograph of the tile pattern that i am trying to achieve, I hope it helps.
    best regards,
    Sam
  1. 2011: Herringbone Hatch Pattern
    By yazici.aliye in forum Revit Architecture - General
    Last Post: 2014-05-14, 06:40 PM
  2. 2012: Showing hatch pattern over material cut pattern
    By frqnt in forum Revit - Platform
    Last Post: 2012-11-16, 08:47 AM
  3. Hatch pattern - error in reading pattern file
    By bbapties in forum AutoCAD Customization
    Last Post: 2011-04-01, 11:40 PM
  4. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
  5. Hatch Boundary deletes if Hatch Pattern is deleted
    By Merlin in forum AutoCAD General
    Last Post: 2006-04-23, 01:01 PM
