Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Herringbone Hatch Pattern
  1. #11
    2018-03
    7
    Default Re: Herringbone Hatch Pattern
    Hi dgorsman;
    Thank you for your reply, so how do I set about creating this pattern using dynamic block?
    regards,
    Sam
  2. #12
    I could stop if I wanted to hugh.69031's Avatar
    2016-01
    Melbourne, Australia
    360
    Quote Originally Posted by sam woodward View Post
    HI hUGH
    I did a sketch but didn't know how to attach the pdf file, i have attached a photograph of the tile pattern that i am trying to achieve, I hope it helps.
    best regards,
    Sam
    Based on the available information showing parallelograms rather than trapeziums:
    ; Written by HatchKit for AutoCAD
    ; HatchKit for AutoCAD (c)1990-2017 Cadro Pty Ltd
    ; www.hatchkit.com.au/
    ;-Date : 2018-03-15
    ;-Time : 14:20:39
    ;-HatchKit Version : 3.1.10.2717
    ;-HatchKit Output Filetype : AutoCAD format
    *chevrons,DXF Entity Section
    44.9934960888,0,141.42,1012.8276065,7.28654125654,500,-13577.5980704
    44.9934960888,0,0,1012.8276065,7.28654125654,500,-13577.5980704
    -44.9934960888,-355.55,494.97,1012.8276065,-7.28654125654,500,-13577.5980704
    -44.9934960888,-355.55,353.55,1012.8276065,-7.28654125654,500,-13577.5980704
    -90,-355.55,494.97,0,711.106782906,141.42,-2.82978301277
    -90,0,141.42,0,711.106782906,141.42,-2.82978301277
    -90,-2,141.42,0,711.106782906,141.42,-2.82978301277
    -90,353.55,494.97,0,711.106782906,141.42,-2.82978301277
    Be assured that hatch patterns are accurate, and can be placed accurately in a drawing.
    hope this helps,
    Hugh
  3. #13
    2018-03
    7
    Hi Hugh,
    Many thanks for your help, I don't know what I would have done without it, you certainly deserve a drink!
    kindest regards,
    Sam
  4. #14
    2017-03
    2
    Hello, could I trouble someone to help me create a herringbone pattern with 200x300 pavers similar to the attached image please, I'm so stuck with the pattern definition....
  5. #15
    2016-01
    360
    Try this:
    ; HatchKit for AutoCAD (c)1990-2018 Cadro Pty Ltd
    ;-Date : 2018-09-27
    ;-Time : 10:32:32
    ;-HatchKit Version : 3.1.11.2769
    *Herringbone300x200,LEFT-HAND 300mmx200mm weave=1/1
    0,0,0,700,-100,500,-700
    90,300,0,700,100,500,-700
    hth,
    Hugh Adamson
    www.hatchkit.com.au
  6. #16
    2018-09
    Dear,
    Can you provide coding for tile size 260x65 with 2mm grout herringbone with 45 angle.
    - - - Updated - - -
    Dear,
    Need coding for Herringbone 260x65 with 2mm Grout, 45 degree angle.
  7. #17
    2016-01
    360
    Quote Originally Posted by khaleelwassu773429 View Post
    Dear,
    try this:
    ; Written by HatchKit 4 Standard Edition
    ; HatchKit 4 Standard Edition (c)1990-2020 Cadro Pty Ltd
    ;-Date : 2021-07-05
    ;-Time : 17:33:28
    ;-HatchKit 4 Version : 4.0.9.2894
    ;-HatchKit 4 Output Filetype : AutoCAD
    *Hrringbone260x65+2,
    45,90.51,-185.26,-529.998950897,6.09196589822,65,-5698.00008676
    45,0,0,-529.998950897,6.09196589822,260,-5503.00008676
    45,-93.338,-1.4142,-529.998950897,6.09196589822,65,-5698.00008676
    45,-45.962,45.962,-529.998950897,6.09196589822,260,-5503.00008676
    135,183.85,183.85,529.998950897,6.09196589822,65,-5698.00008676
    135,136.47,-139.3,529.998950897,6.09196589822,260,-5503.00008676
    135,0,0,529.998950897,6.09196589822,65,-5698.00008676
    135,90.51,-185.26,529.998950897,6.09196589822,260,-5503.00008676
    hth,
    Hugh Adamson
    www.hatchkit.com.au
  1. 2011: Herringbone Hatch Pattern
    By yazici.aliye in forum Revit Architecture - General
    Last Post: 2014-05-14, 06:40 PM
  2. 2012: Showing hatch pattern over material cut pattern
    By frqnt in forum Revit - Platform
    Last Post: 2012-11-16, 08:47 AM
  3. Hatch pattern - error in reading pattern file
    By bbapties in forum AutoCAD Customization
    Last Post: 2011-04-01, 11:40 PM
  4. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
  5. Hatch Boundary deletes if Hatch Pattern is deleted
    By Merlin in forum AutoCAD General
    Last Post: 2006-04-23, 01:01 PM
