Results 1 to 7 of 7
Thread: closed alignment
    2004-06
    Slidell, Louisiana
    968
    Default closed alignment
    Is it possible to have a closed alignment? i.e. i want to create a corridor for a small parking lot with a center island.
    i plan to use a curb & gutter assembly around the island and the outer perimeter of the the parking area and create a corridor and top surface.
    i will have an alignment around the perimeter and a separate alignment around the island.
    I know in the newer versions, you can use a feature line as the baseline for a corridor.
    Earth
    9,803
    Default Re: closed alignment
    Good question. Are you going to be stationing objects/points off this alignment?
    Consider what happens in the area where the end is near the beginning.
    Labels will pick up the station on the alignment point closest to the point, which may not be the part of the alignment you want.
    Consider the labeled point in the image below. (The alignment loops around from the left edge of the image clockwise to the top center)
    If that point is a feature off of the horizontal part of the alignment, it's station might be 1+05.xx
    But since it's closer to the vertical segment, it gets labeled 10+96.xx
    R.K. McSwain | CAD Panacea |
    2004-06
    Slidell, Louisiana
    968
    i don't think i'll need to do any stationing and offsets. i just need the alignment to create a corridor using a curb/gutter assembly for the parking lot.
    the only labeling may be spot elevations and/or slope
    thanks for the info. didn't think about how it might label stationing.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,096
    If you are creating a surface from this corridor, be aware closed loops within corridors do not allow the shrinkwrap boundary to function as you expect. I would use multiple corridors (as needed) to create a site wide surface.
    2003-07
    555
    If you have a very tiny misclose can help for me 1mm, the other to be aware of you must have a +v -ve grade match at the two end points its pretty easy to get a different answer at the two ends.
    2020-02
    My alignment is a polyline that is closed, therefore sta 0+00 is also sta 500+05.15 I only want the 0+00 to show up but it automatically also shows the last station, not sure how to fix this.
    2015-10
    Central New Jersey
    439
    Edit your alignment labels. There is a place for geometry labels where you can select which geometry points get labeled.
    - - - Updated - - -
    Hold down the CTRL key and select the label. In the properties window there is a place to set the Visibility to False.
  1. 2017: Convert Promoted Alignment to Referenced Alignment
    By dmonk58 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2017-05-11, 08:30 PM
  2. 2012: How to create points on LHS alignment which are at even chainage w.r.t the main centreline alignment
    By gary.chan.kc355500 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2013-04-25, 07:25 PM
  3. Alignment Station label that is perpendicular to alignment
    By corboto in forum AutoCAD Civil 3D - Alignments
    Last Post: 2010-05-20, 10:43 PM
  4. Grading alignment to alignment..
    By whf in forum AutoCAD Civil 3D - Grading
    Last Post: 2009-05-15, 09:08 PM
