Does anyone know if there is some sort of setting for point style trimming? See attached image.
The one in the top left is the block and it trims fine.
The one in the bottom right is the same block, but in a point style. The trimming is not anywhere near correct.
The point style is set to a fixed scale, so the point will not scale up or down based on drawing scale.
Thanks
Edit: I also just confirmed that it appears that the rotation of the block throws it for the loop. I can trim it fine if no rotation occurs, but once rotated the trimming becomes off.
