Thread: Alignment tool won't snap to blocks with hatch (solid fill)
    2004-06
    Oklahoma
    19
    Default Alignment tool won't snap to blocks with hatch (solid fill)
    I have created multiple dynamic blocks (DB). They work great! Recently, I was asked to put shading in my DB for my ductwork. All works well except for the alignment tool will not align perpendicular to another block with a solid hatch. I've tried to bring the lines around the hatch to the front with draw order. Still no worky.
    Anyone encounter this issue or have a work around?
    I have attached a drawing with my dynamic blocks to test.
    Thx
    MBM
    6,409
    Default Re: Alignment tool won't snap to blocks with hatch (solid fill)
    Can you explain a little more regarding what workflow you are using. I'm not sure what you mean by the 'alignment tool'. Are you talking about the ALIGN command?
    LinkedIn
    2004-06
    Oklahoma
    19
    My blocks have the alignment parameter built into the block. With the blocks already inserted into the model space. Click on a DB, then grab the alignment parameter and drag it next to the side of the block you want it to align with. When trying to align the block does rotate or flip to the correct orientation.
    Try to build the original blocks to look like the attached modified while using the align parameter in the dynamic blocks.DB - Alignment issues.jpg
    6,409
    The only workaround I've found so far is to turn off the PATT layer while inserting or using the alignment grip.
    LinkedIn
  1. 2018: Solid Hatch in Exit sign family not solid...
    By COBIMUSER in forum Revit MEP - General
    Last Post: 2018-05-30, 09:48 PM
  2. Replies: 1
    Last Post: 2013-01-28, 12:52 PM
  3. nested solid fill pattern DC won't show in RCP
    By Ning Zhou in forum Revit Architecture - Families
    Last Post: 2011-10-19, 09:23 PM
  4. Fill pattern with solid and hatch
    By dfi in forum Revit Architecture - General
    Last Post: 2011-09-14, 12:05 PM
  5. Importing Autocad Fill (Solid or Solid Hatch)
    By Jit in forum Revit Architecture - General
    Last Post: 2004-04-20, 12:51 AM
