Thread: Annotation Text Height Issue
    Exclamation Annotation Text Height Issue
    Hi,
    When managing my annotation text style, I try to change the "Paper Text Height" from 1/8" to 3/32". The dialog box will not accept an entry of 3/32", it reverts back to 1/8".
    I'm trying to make this particular annotation text style smaller, for when I plot it, it is much too large for my plotter.
    I even attempted creating a new text style, and I am still not able to create a Paper Text Height of 3/32"..
    Any advice or suggestions would be most helpful.
    Thanks in advance,
    -Ben
    2005-06
    in the upper right corner
    3,507
    Default Re: Annotation Text Height Issue
    Quote Originally Posted by benoitellisclement765723 View Post
    Hi,
    Thanks in advance,
    -Ben
    When you say it will not except 3/32", do you mean it won't show it as 3/32"?
    Meaning you ARE changing it but it only displays in the dialog as 1/8"?
    If so, have you checked your "units"?
    I could be you have a precision of 1/16" and you need to change it to 1/32" and it will display properly.
    Just a thought.
    that was real helpful! Thanks I got it fixed!
    Just a thought.
  1. 2013: Can I make text style height control label text heights?
    By caddjockey2000 in forum AutoCAD Civil 3D - General
    Last Post: 2013-12-05, 04:25 PM
  2. Lock Text Height in Dimension Style when Text Style Height is Not 0
    Last Post: 2013-01-16, 04:55 AM
  3. changing text height inside text component editor
    By smcgypsea in forum AutoCAD Civil 3D - Pipes
    Last Post: 2010-04-29, 11:44 AM
  4. Set text height automatically to the correct height of your dimscale.
    By kastmiler in forum AutoCAD Tips & Tricks
    Last Post: 2006-03-16, 08:33 PM
  5. Set Text height, then issue the MText command
    By dhurtubise in forum AutoLISP
    Last Post: 2006-02-20, 04:05 PM
Tags for this Thread
