Thread: Area schedule. Schedule form: areas calculation name*level
    2016-10
    5
    Default Area schedule. Schedule form: areas calculation name*level
    Is there any possibility to make area schedule like this? (see example in attach). Horizontal area names, vertical levels
    2002-09
    Madison, WI
    5,687
    Default Re: Area schedule. Schedule form: areas calculation name*level
    At first I thought no you can't.
    But you could if each of those Area Types (Departments) were their own parameter. Then you could do it.
    Otherwise I think I'd be looking at a Dynamo solution exported to Excel. Doing this in one step would be complex but might be possible.
    Or a Export multiple sets of data to unique sheets via Dynamo. Say a list for each department sorted by level.
    Then in your final sheet link each cell to data from the previous sheets.
    PowerBI might be able to help you out here as well.
  1. 2014: Schedule room area in a window schedule
    By rudolfweyers346383 in forum Revit Architecture - General
    Last Post: 2013-09-17, 01:38 PM
  2. 2014: Schedule: Font text and size of the schedule in the gray area
    By lbk in forum Revit Architecture - General
    Last Post: 2013-08-20, 11:04 PM
  3. Schedule calculation
    By t1.shep in forum Revit Architecture - General
    Last Post: 2009-11-18, 06:39 PM
  4. Level Area Calculation
    By shifali.a in forum Revit - API
    Last Post: 2009-02-06, 10:04 AM
