Thread: Surface Mask
    2009-11
    Raleigh, NC
    943
    Default Surface Mask
    Does a Surface Mask perform the way a Boundary would?
    I have three streets that enclose an area within a townhouse development. I have an outside boundary enclosing the whole proposed grading surface generated by a network of baselines of a Corridor Model.
    Now I am wanting to do my volume calcs and I want to know if the mask that has been turned of for the visual example below is acting as a boundary for the TIN as well or is it just covering the contour lines?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: Surface Mask
    A Surface Mask does not remove the surface below the mask. It only prevents it from displaying.
    I would suggest splitting your corridor into two or more corridors. A combined corridor will create an island. This island is not removed from the surface by adding a dynamic shrink-wrapped boundary.
  1. 2016: Civil 3d Surface - Building with split levels - How to accurately show in surface for fill
    By Toni@Simpkins-Costelli in forum AutoCAD Civil 3D - General
    Last Post: 2016-06-10, 06:16 PM
  2. Replies: 0
    Last Post: 2012-10-24, 04:55 PM
  3. Surface Mask Contour Problem
    By richard_bauer in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-10-18, 10:22 PM
  4. Surface Mask C3D 2010
    By dabbondondolo in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-04-05, 04:59 PM
  5. Surface Background Mask
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-07-01, 01:08 PM
