Thread: Mapimport and object data tables
    Cairo - no, not Illinois
    5,069
    Default Mapimport and object data tables
    I suspect i'm forgetting something pretty simple, but I've been pulling in SHP files, and telling Mapimport to Create Object Data in the dialog. If I view properties for any thing that came in from the import, I can see the Object Data that I expect, but when I try to run a query, Map acts like there are no Object Data Tables.
    IIRC this _used _ to work, but this time around, nada, zip, nuttin.
    9,805
    Default Re: Mapimport and object data tables
    Don't you have to MapAttach the drawing with the objects+data, and then run the query on the Attached drawing?
    TN/KY Area
    1,640
    Yes and no. You can query the current dwg from the map display tab. Click Data icon, then Add Drawing Data, Query Current Drawing
    5,069
    well, that got me one step closer, the query dialog will come up, and I can pick the value from the table listing, but can't do anything else -- execute is grayed out,
    basically I'm trying to identify/select/alter properties for a single named river in a water shed, and follow that up with identifying all named streams. Other than clicking on every segment and looking at the Properties dialog,
  1. 2014: Added object data fields to Polyline, but object data is empty or zero
    By tntdraftsol in forum AutoCAD Map 3D - General
    Last Post: 2015-07-24, 12:20 PM
  2. How to Convert a drawing file with linked database tables to Object Data
    By adrianhedley in forum AutoCAD Map 3D - General
    Last Post: 2010-04-20, 03:07 PM
  3. LINKING OBJECT DATA TO TABLES
    By knickers in forum AutoCAD Tables
    Last Post: 2009-08-10, 08:09 PM
  4. Object data tables
    By jim.dahl in forum AutoCAD Map 3D - Wish List
    Last Post: 2005-08-18, 04:16 PM
