Thread: contours
    2004-06
    Slidell, Louisiana
    972
    Default contours
    I have imported a dem file and created contours lines in map3d. is there a way to export those contour lines with elevation to be used in a cad dwg?
    Earth
    9,804
    Default Re: contours
    Select the Surface Object.
    On the Contextual Surface Tab, in the "Surface Tools" panel, select "Extract from Surface > Extract Objects"
    Select the appropriate objects to extract.
    Done.
    More info
    R.K. McSwain | CAD Panacea |
    2004-06
    Slidell, Louisiana
    972
    I don't have a civil 3d surface. i connected to a dem file and create a surface layer in map 3d. these contours always look smoother than the ones in civil 3d from the same dem file.
    so i'm trying to see if i can export them as some type of file that can then be imported into civil 3d.
    Earth
    9,804
    Oops, sorry. I did not pay attention to the Forum in which this was posted.
  1. Contours
    By spaynter08 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-03-27, 02:13 AM
  2. Contours
    By drafting.33933 in forum AutoCAD Civil 3D - General
    Last Post: 2008-10-28, 07:11 PM
  3. Contours
    By chrisr in forum ACA General
    Last Post: 2005-02-12, 10:04 PM
