Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Adding Surfaces that represent concrete slabs
  1. #11
    2017-10
    Default Re: Adding Surfaces that represent concrete slabs
    Just curious, I don't use C3D, but (our surveying dept does) any reason you can't use solids for the slabs?
    Surfaces in Civil 3D are TINs. Triangulated Irregular Network. A solid doesn't work with a TIN. Here is a quick bit of information on a TIN. https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Civil3D-UserGuide/files/GUID-D0FCED34-D68F-42D2-A6FB-14C454CA57FA-htm.html
  2. #12
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by adammreilly View Post
    I typically do my slabs backwards from Opie's method. I'll offset 0.05 outward and keep the slab matching the outline of the building. Primarily because I also use a line label to label the building, with area, and reference the surface to give the FFE. It pulls the elevation at the polyline that I label. Opie's method makes it easier to add spot elevations, as I tend to have to use a temporarily offset object to snap my labels to.
    But, oh how I wish we could just use actual 3d objects and tell Civil 3D to use specific faces of it as surface definition data.
    My method is used for modeling purposes. Our model is then data referenced into sheets for display and labeling. We need to make it simpler for drafting to label the correct locations. I have enough issues with my drafters getting spot elevations in the correct location at curbs.
  1. Coffer - Waffle type concrete slabs
    By Griff in forum Revit Architecture - General
    Last Post: 2010-06-10, 01:54 PM
  2. tapered concrete slabs
    By tom.psaris in forum Revit Structure - General
    Last Post: 2009-04-22, 01:17 PM
  3. Wire Mesh Reinforcement in Concrete Slabs
    By j.pilot in forum Revit Structure - General
    Last Post: 2008-08-25, 06:33 AM
  4. concrete slabs with multiple slopes Revit 2008
    By Tea_Berries in forum Revit Architecture - General
    Last Post: 2007-06-04, 02:09 PM
  5. Joining concrete beams to slabs
    By paullee in forum Revit Structure - General
    Last Post: 2006-08-29, 02:51 PM
