Thread: Annotation Text Height - Real Confused! *Screenshots Incl.*
    Default Annotation Text Height - Real Confused! *Screenshots Incl.*
    I am wondering why annotation text height does not seem to be displaying correctly, so I:
    • checked the present drawing annotation scale
    • checked the selected text style Paper Text Height
    • made sure "Show Annotation Objects" is toggled on
    • checked the properties of the mtext object and verified the Paper Text Height" matched the Text Style's "Paper Text Height"
    Now get this, I created a second text style "Med Notes" and set the text styles settings to be the same as the original text style I was working with (named "Notes - Small")....
    And both text styles display different text heights! I'm so confused.
    Screenshots below:
    2003-03
    Philadelphia, PA
    2,392
    Default Re: Annotation Text Height - Real Confused! *Screenshots Incl.*
    You are a victim of your linear units precision, which, I am guessing, is set to round numbers to the nearest 1/8".
    The giveaway here is the listed model text height for the two texts. The Notes - Small text is listed as having a model height of 1 1/8". At a scale of 1" = 1'-0" (1:12), that corresponds to a paper height of 3/32", which, rounded to the nearest 1/8", is 1/8". The style you created, Med Notes, based on what you saw on the screen for the other style, has a model height of 1 1/2" at 1" = 1'-0", which corresponds to a paper height of 1/8" (without rounding).
    At the command line, type LUPREC and press the ENTER key. I bet the default value is 3. Type 5 and press the ENTER key. Now check your text style definitions again. You should find that Notes - Small has a paper height of 3/32" while Med Notes still shows 1/8".
    While I will usually limit my dimension style precision to the nearest 1/8", I set the units to Engineering Units (feet and decimal inches), with the precision set to 6 to 8, both to avoid small errors in drawing, which can combine to large errors and to avoid the confusion you are experiencing.
  1. Annotation Text Height Issue
    By RegenerativeEducator in forum AutoCAD Annotation
    Last Post: 2018-03-30, 06:07 PM
  2. Replies: 0
    Last Post: 2014-12-01, 05:02 AM
  3. Lock Text Height in Dimension Style when Text Style Height is Not 0
    Last Post: 2013-01-16, 04:55 AM
  4. Replies: 7
    Last Post: 2008-04-28, 07:13 PM
  5. Set text height automatically to the correct height of your dimscale.
    By kastmiler in forum AutoCAD Tips & Tricks
    Last Post: 2006-03-16, 08:33 PM
Tags for this Thread
