Thread: Get composition of a object block without exploding it
    2005-04
    Default Get composition of a object block without exploding it
    Hello,
    To know what's in a block, I'm using
    exploded=object.explode ' explode a block
    explodedObjects = object.Explode
    For i = 0 To UBound(explodedObjects)
    Prompt explodedObjects(i).ObjectName
    Select Case explodedObjects(i).ObjectName
    Case "AcDb2dPolyline"
    end select
    end for
    Is there a possibility without exploding ?
    Deniz
    100 Club RobertAitken's Avatar
    2000-10
    Sunny Scotland
    148
    Default Re: Get composition of a object block without exploding it
    Quote Originally Posted by d.cakmur
    Hello,
    Deniz
    Sorry for the this answer but it's been awhile.
    Short answer Yes you can.
    It's more to do with the block reference than the block object itself. This is where Ed and RRB correct me.
    You can iterate through the block references and blocks and change them without exploding. I don't have any code to had that would show you. But it is possible.
    You can for instance change the colours of entities with blockreferences and blocks programatically.
    I know it's not much help but it might set you in the right direction.
    Robert Aitken
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by robert.3.aitken
    <snort>
    To gat at the objects in the block, you simply need to iterate thru the Block object in the Blocks collection.
    Dim myBlock as AcadBlock
    Set myBlock = ThisDrawing.Blocks.Item("MySample")
    Dim anEntity as AcadEntity
    For Each anEntity in myBlock
      'working code here
    Next anEntity
    2000-10
    Sunny Scotland
    148
    Quote Originally Posted by RobertB
    <snort>
    'working code here
    Next anEntity
    See, I knew it was something simple
    Robert
    Turlock, CA
    6,373
    PS, once you have the AcadBlock object, it has an Items property that returns the block's objects.
    C:> ED WORKING....
  1. Allow block exploding
    By chadwickt in forum AutoCAD General
    Last Post: 2012-01-24, 11:14 PM
  2. Insert new block attribute without exploding...
    By jnantel in forum AutoCAD General
    Last Post: 2010-01-07, 11:27 PM
  3. Insert dynamic block without exploding
    By curtis.hatfield in forum Dynamic Blocks - Technical
    Last Post: 2009-10-26, 04:56 PM
  4. Need help exploding huge block
    By jdrewreed in forum AutoCAD General
    Last Post: 2009-07-09, 05:54 PM
  5. Exploding block references
    By mike.83572 in forum AutoCAD General
    Last Post: 2005-03-02, 10:48 PM
