Results 1 to 7 of 7
Thread: Rotate selected attribute to zero degrees
    2001-01
    257
    Default Rotate selected attribute to zero degrees
    Hi All
    I have the following routine that use to rotate visible attributes to zero degrees. It works well but occasionally when I am in a hurry and I miss the selection it locks up my session. I would like to add the necessary code to check that something valid has been selected. I tried the following code but it did not. Any help is greatly appreciated. Thanks.
    Manuel
    (defun c:A0 (/ en)
    (if
      (and
       (setq en (car (entsel "\nSelect attribute to rotate: ")))
       (wcmatch (cdr (assoc 0 (entget en))) "ATTRIB")
       (command ".attedit" "" "" "" "" en "" "a" "0" "")
    2010-06
    962
    Default Re: Rotate selected attribute to zero degrees
    Hi,
    Please try the following routine that allows you to have multiple selection on Attributed blocks and ignores the invisible attributed to be rotated to zero degree.
    (defun c:Test (/ sel int ent get)
      ;; Tharwat - Date: 24.04.2018	;;
      (and (princ "\nSelect attributed blocks to rotate: ")
           (setq sel (ssget "_:L" '((0 . "INSERT") (66 . 1))))
           (repeat (setq int (sslength sel))
             (setq ent (ssname sel (setq int (1- int))))
             (while (/= (cdr (assoc 0 (setq get (entget (setq ent (entnext ent)))))) "SEQEND")
               (or (= (cdr (assoc 70 get)) 1)
                   (entmod (subst '(50 . 0.0) (assoc 50 get) get)))
    2001-01
    257
    Thanks Tharwat. That works nicely. Take care.
    Manuel
    2010-06
    962
    Quote Originally Posted by cadconcepts View Post
    Manuel
    You are welcome anytime Manuel.
    2001-01
    257
    Hi Tharwat
    Is it possible to only rotate the selected attribute? The way it is written, it changes all attributes values in a block. Thanks.
    Manuel
    2010-06
    962
    Yeah and here you go.
    (defun c:Test (/ sel int get )
      ;; Tharwat - Date: 13.09.2022		;;
           (setq sel (nentsel "\nPick on attribute to rotate : "))
           (or (member '(0 . "ATTRIB") (setq get (entget (car sel))))
               (alert "Invalid object selected. Try again")
    2001-01
    257
    Hi Tharwat
    Thank you. I will give it a try.
    Manuel
  1. Replies: 6
    Last Post: 2014-09-24, 08:11 AM
  2. 2014: Rotate Specific Plan 180 Degrees
    By Limbatus in forum Revit Architecture - General
    Last Post: 2014-04-29, 11:14 PM
  3. ACAD Mech 07 - Double-click Attribute to open editor on selected Attribute
    By svanderputten in forum AutoCAD Mechanical - General
    Last Post: 2012-01-25, 06:08 PM
  4. Rotate 90 Degrees
    By ntopliffe in forum Revit MEP - General
    Last Post: 2009-08-14, 01:05 AM
  5. PDF's rotate 90 degrees on output
    By BrenBren in forum AutoCAD Plotting
    Last Post: 2007-01-17, 09:01 PM
