Thread: corridor experiment
    2004-06
    Slidell, Louisiana
    772
    Default corridor experiment
    i've been playing around with some ideas of using corridors to build concrete house foundations. haven't gotten it to work as hoped just yet.
    anybody have an assembly they care to share or ideas of how to accomplish this?
    i was fairly successful with using a link width and slope sub-assembly on each side of the assembly and using the front line of the slab and targeting the rear edge, but it only gives me the top surface.
    i then built a sub-assembly from a polyline depicting the shape of a monolithic footing and slab, but it didn't work as hoped. it was a square slab and the last corner didn't clean up like the others.
    Robert
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,405
    Default Re: corridor experiment
    Instead of targeting the rear edge, have you tried targeting a offset line that is closer to the middle of the slab?
    Do you have a sample image or drawing to show others to get a better understanding of what you are doing?
    2004-06
    Slidell, Louisiana
    772
    unfortunately no, the dwg crashed at one point and it didn't save the work i had done and i haven't tried recreating it.
    so, are you saying i should try creating it with two regions, basically both halves of the slab? that kinda makes sense, since i'm using a feature line as the alignment, which is a closed alignment, which is what i
    think the problem is by not being able to clean up that last corner.
    Robert
    I could stop if I wanted to tntdraftsol's Avatar
    2008-03
    Columbia/Jefferson City, MO
    224
    Quote Originally Posted by rmk View Post
    For what purpose are you wanting the corridor model of the foundations to serve? Do you want a surface of the foundation, or a visualization of the shapes? If it is a surface you want from it, I'm not sure how that could be accomplished with so many 90 degree angles. If you are wanting the shapes, you could use some of the OOTB retaining wall subassemblies that would get you close and extract the shapes from the corridor.
    You have sub-assembly composer as an option too if you want to try and create your own.
    Mike Tuter
    Engineering Design Technician
    Missouri Department of Conservation
    Revit Structure Certified Professional
    @CAD_Minion
    2013-08
    Cool Re: corridor experiment
    If its the solid that you want, and the shape of the solid is constant, you could also try the SWEEP command (also available by switching to the 3D modeling workspace). The sweep command allows you basically take a consistent 2D shape and pull it along a path (like an alignment/profile, or featureline) to create a surface or solid object. See the link below for help for using the SWEEP command.
    AutoCAD Civil 3D Help: About Creating a Solid or Surface by Sweeping
    If your wall varies in height, and therefore you need to be able to target an elevation, I would second the previous suggestion to look at using one of the retaining wall subassemblies or look into creating a custom subassembly in subassembly composer.
  1. Corridor LandXML to include the true corridor & associated objects
    Last Post: 2015-11-16, 11:00 AM
  2. quick experiment
    By Max Lloyd in forum Revit - Gallery
    Last Post: 2011-10-14, 04:25 AM
  3. Poll Experiment
    By dkoch in forum New Forum Users (Non technical)
    Last Post: 2006-05-16, 02:22 PM
