why is it when you draw a polyline and using the endpoint osnap to pick the endpoint of the first line you drew, it's not a closed figure.
after drawing this, i selected the supposed closed figure and go to properties, it shows it's not a closed figure. i've even set the units to maximum decimal place
and id'd both endpoints and the coordinates are exactly the same.
I know you can select close and close the figure, and you can pick yes to close it in the properties dialog, just curious as to why this occurs.
i ran across this when trying to create parcels from what i thought were closed figures, but it fact they weren't.
thanks for any input.
