Thread: Intersecting gradings with different slopes and program keeps freezing on the second one
    100 Club jgrande26's Avatar
    2001-10
    Down the rabbit hole
    196
    Default Intersecting gradings with different slopes and program keeps freezing on the second one
    I'm not very proficient with Civil 3d because I don't get the opportunity to use it often. I created two feature lines that form a rough rectangle. I created two grading groups to grade to my finished elevation. One feature line has a 3:1 slope, the other 4:1. I was able to grade the first line, but every time I try to grade the second, C3D freezes. I'm not sure if it's because I'm doing something wrong/not best practice/etc, or if my computer doesn't have enough "power".
    Win 7 Pro, SP1 64 bit
    Intel Core i5-3470 CPU @ 3.2 GHz
    8 GB RAM
    Civil 3D 2018
    File located here: https://www.dropbox.com/s/h2tz0b3ugf...018.1.dwg?dl=0
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,096
    Default Re: Intersecting gradings with different slopes and program keeps freezing on the second one
    I'm assuming you are grading the second feature line on the right toward the currently graded feature line on the left.
    First, your existing surface appears to have vegetation included within the model. You might try to flatten those areas to help with your existing surface.
    I would join the two feature lines before grading. They are on the same site, so they will interact where they cross anyway. Once joined, I would grade the most of the left side using the desired criteria, leaving a length on each end to allow for a transition between slopes. Then repeat with the right side of the feature line, again leaving space on each end to allow for a transition. Once you have graded each side with the desired criteria, add a transition slope between the two previous grading objects.
    Also, you may need to invest in a bit more RAM. That is a tad low for Civil 3D. It is doable, but is not recommended. I've worked with it with less. It was not enjoyable to work with.
    2001-10
    196
    Thanks, I'll try that. What method do you recommend to flatten the vegetated areas?
    I've been asking for a hardware upgrade for more than a year now.
    2002-01
    jUSt Here (a lot)
    9,096
    Draw a boundary (i.e.: polyline or feature line) around the areas where vegetation appears. Then set the elevation of that boundary to the existing surface. Create a new surface for that area. You could then paste the new surface into the current surface.
    As long as this new surface is further down in the definitions list of the surface, it will override the vegetative areas. Otherwise, you could paste both surfaces into a new one, again following the proper order in the definitions tab of the surface properties dialog box.
    2001-10
    196
    Thank you Opie. It took some fiddling, but I finally accomplished what I was trying to do.
  1. 2017: Create multiple gradings from multiple feature lines.
    By Jim_Poole in forum AutoCAD Civil 3D - Grading
    Last Post: 2017-04-27, 02:19 PM
  2. Intersecting walls
    By h.s.meijering in forum Revit - Student Support
    Last Post: 2010-02-16, 03:46 PM
  3. Writing a Short program from Large Program
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-07-13, 01:26 AM
  4. Fix Self Intersecting Problems
    Last Post: 2006-04-28, 01:51 PM
