Hello
any help to write a lisp that can print on screen dx and offset of a picked point relative to polyline as shown in attached image
thanks
Hello
thanks
Hi,
I am not sure that I got your point clearly so more details is required I guess.
Can you please write down the steps of the program that you are after?
eg: Select polyline, then Specify a point , .... etc
Thank you tharwat for reply
step for input
1-pick the polyline
2-pick any place on screen to find dx and offset of this place relative to polyline
3-pick place to print dx and offset on screen
Can you please clarify what is the meaning of DX ? Is it a text, a point, ... ect ?
What to offset? the polyline or draw a polyline from that DX point perpendicular to the main polyline?
A drawing with before and after would help a lot to describe the issue.
offset is the perpendicular distance between picked place and polyline
dx is the distance between start point of polyline and the fallen point of a picked point on the polyline
dx is the same delta x
soo offset and delta x is a number to be print on screen attached with a leader
Hi,
Something like this?
Code:(defun c:Test ( / s p c a d) ;; Tharwat - 28.May.2018 ;; (if (and (setq s (car (entsel "\nPick a polyline :"))) (or (= (cdr (assoc 0 (entget s))) "LWPOLYLINE") (alert "Invalid object! Please pick a polyline only.") ) (setq p (getpoint "\nSpecify point perpendicular to polyline :")) (setq c (vlax-curve-getclosestpointto s p)) (setq a (angle p c)) (not (grdraw p c 1 -1)) ;; rubber line in red colour. (setq d (angle '(0. 0. 0.) (vlax-curve-getfirstderiv s (vlax-curve-getparamatpoint s c)))) (or (or (equal (rem (+ d (* pi 0.5)) (+ pi pi)) a 1e-4) (equal (rem (+ d (* pi 1.5)) (+ pi pi)) a 1e-4) ) (alert "Picked point is not a perpendicular to picked polyline. <!>") ) ) (command "_.leader" "_non" p "\\" "" (strcat "DX= " (rtos (vlax-curve-getdistatpoint s c) 2 4) "\\P" "Offset= " (rtos (distance c p) 2 4)) "") ) (princ) ) (vl-load-com)
Last edited by Tharwat; 2018-05-28 at 11:46 AM. Reason: Added extra check-up codes for the angle
wow very nice lisp tharawat
one more thing i want if the picked point is outside the length of polyline
the dx distance will be minus value as shown on image
second need to add while if i have to repeat different point
thanks
Hi,
Please try this program and let me know.
Code:(defun c:Test (/ *error* oblique ray_ b s p c a d m l z e r) ;; Tharwat - 29.May.2018 ;; (defun *error* (msg) (and r (vla-delete r)) (princ "\n*cancel*") ) ;; ;; (defun oblique (ent pnt) (angle '(0. 0. 0.) (vlax-curve-getfirstderiv ent (vlax-curve-getparamatpoint ent pnt) ) ) ) ;; ;; (defun ray_ (spc pt1 pt2) (vlax-invoke spc 'addray pt1 pt2) ) ;; ;; (setq b (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)) ) ) ) (cond ((= 4 (logand 4 (cdr (assoc 70 (setq e (entget (tblobjname "LAYER" (getvar 'clayer)))) ) ) ) ) (alert "Current layer is locked <!>.") ) ((minusp (cdr (assoc 62 e))) (alert "Current layer is off <!>.") ) (t (while (and (setq s (car (entsel "\nPick a polyline :"))) (or (= (cdr (assoc 0 (entget s))) "LWPOLYLINE") (alert "Invalid object! Please pick a polyline only.") ) (setq p (getpoint "\nSpecify point perpendicular to polyline :") ) (setq c (vlax-curve-getclosestpointto s p)) (setq a (angle p c)) (setq d (oblique s c)) (or (or (equal (rem (+ d (* pi 0.5)) (+ pi pi)) a 1e-4) (equal (rem (+ d (* pi 1.5)) (+ pi pi)) a 1e-4) ) (progn (setq m (vl-sort (mapcar '(lambda (q) (cons (distance p q) q)) (list (vlax-curve-getstartpoint s) (vlax-curve-getendpoint s) ) ) '(lambda (j k) (< (car j) (car k))) ) z (cdr (car m)) r (ray_ b z (polar z (+ pi (oblique s z)) 1.0)) c (vlax-curve-getclosestpointto r p) l (distance c z) ) (vla-delete r) (if (zerop l) (progn (setq r (ray_ b z (polar z (oblique s z) 1.0)) c (vlax-curve-getclosestpointto r p) l (distance c z) ) (vla-delete r) ) ) l ) ) ) (command "_.leader" "_non" p "\\" "" (strcat (if l (strcat "DX= -" (rtos l 2 4)) (strcat "DX= " (rtos (vlax-curve-getdistatpoint s c) 2 4)) ) "\\POffset= " (rtos (distance c p) 2 4) ) "" ) ) ) ) (princ) ) (vl-load-com)
Last edited by Tharwat; 2018-05-29 at 09:38 PM. Reason: A few lines of codes adjusted.
thank you tharwat you are a great man
code is complete
