Results 1 to 1 of 1
Thread: Adopted Code Schedule
    2018-03
    7
    Default Adopted Code Schedule
    I am creating a key schedule using the attached script and excel file. The script works fine but I would like to be able to utilize a pull down list of the sheets in the excel file to allow users to bring in that jurisdictions data (or better yet get the project address from the revit project information parameter so the user just runs the script and it reads the data and imports only that sheets data). When I hook up the 2 nodes to create the list it only shows the first 2 sheets? So I am stuck. Thoughts?
  1. Allow Other Code Compilers for ARX Code
    Last Post: 2013-02-10, 08:06 AM
  2. Schedule Code References, Link Schedules in Text
    Last Post: 2012-12-28, 10:45 PM
  3. Insert vbscript code has not code
    By buzz in forum AMEP General
    Last Post: 2008-02-09, 03:08 AM
  4. Convert VBA code to VB code
    By Robert Platt in forum VBA/COM Interop
    Last Post: 2007-08-15, 10:13 PM
