Thread: spiral-curve-spiral-curve-spiral-curve-spiral alignment?
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default spiral-curve-spiral-curve-spiral-curve-spiral alignment?
    For the most part, I can make use of the spiral-curve-spiral transition between tangents (s-c-s).
    I can almost wrap my brain around the spiral-curve-spiral-curve-spiral transition (s-c-s-c-s).
    In Civil-3d is there such a thing as a spiral-curve-spiral-curve-spiral-curve-spiral in an alignment? (s-c-s-c-s-c-s -- that's three curves and four spirals)? How can I do such a thing?
    2014-08
    447
    Default Re: spiral-curve-spiral-curve-spiral-curve-spiral alignment?
    Hi
    with some planning I would suggest having each segment penciled out and ready to go. make a alignment tangent even if we delete it later. then build each segment as you go. I believe to make the 1st spiral you have to make the curve also then just keep adding each piece
  1. 2016: Spiral-curve-spiral 180 degree turn
    By Maverick91 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2016-01-15, 04:29 PM
  2. 2014: Error creating Spiral to Spiral
    By justinpickens77701535 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2015-06-03, 07:59 PM
  3. Adding spiral-curve-spiral between lines, like fillet?
    By Maverick91 in forum AutoCAD Civil 3D - General
    Last Post: 2011-08-12, 03:25 PM
  4. Spiral
    By clivewright in forum AutoCAD General
    Last Post: 2005-06-02, 06:04 PM
Tags for this Thread
