Thread: BIM360/Collaboration for revit
    2005-05
    44
    Angry BIM360/Collaboration for revit
    Was wondering how you change where revit saves it's cache/temp files? Currently it's in C:\Users\Michael\AppData\Local\Autodesk\Revit\Autodesk Revit 2018\CollaborationCache currently and is eating up all my c drive space. Wanted to change to my d drive that has more space to use. Also if thats not possible how do I clean up that folder as it's currently 20gb plus and each project i add to bim360/c4r i'll run out of space quickly.
    Using revit versions 2016-2018 if that is needed for reference.
    Thanks
    100 Club a_meteni's Avatar
    2002-12
    Cairo
    167
    Default Re: BIM360/Collaboration for revit
    This post might help
    Best Regards
    Ali
    2005-05
    44
    have read that one, thing that worried me was at bottom about data loss/corruption so was hoping there was a way less problematic then that.
    2002-09
    Madison, WI
    5,674
    Easiest way to clean that up is simply delete the files. We typically try to get people to do that about once a month or so. It'll take longer to open the file, but is something you need to do.
    We've also set the local file location for non BIM360 projects to a specific folder and we have a script that runs to delete anything more than 30 days old I believe.
    We've also seen those go corrupt from time to time. If the file hasn't been accessed by someone in a few weeks on an active project, it' might just be better to download the whole thing anyway. When we see errors upon opening, that's one of the first trouble shooting things we do. Delete the local files for the project and have them start fresh. That seems to fix most things.
    Dave Peterson
    BIM Coordinator
    Acad - 2019 - Revit 2020 w/ BIM 360 - Navisworks - 3ds 2020 - Ensacpe - Lumion - Win 7 64 - i7-8086K 4.0GHz 32GB Ram - Nvidia Quadro P2000
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
  1. 2018: Información de REQUESTS en un modelo compartido (BIM360)
    By JVillarroel in forum Español - Revit
    Last Post: 2018-01-12, 03:31 PM
  2. Collaboration for Revit
    By denverdave in forum BIM Management - General
    Last Post: 2016-07-07, 04:04 PM
  3. Replies: 1
    Last Post: 2013-03-15, 09:43 PM
  4. Revit Structure Collaboration
    By CADdancer in forum Revit Structure - General
    Last Post: 2009-12-09, 09:16 PM
  5. Collaboration in REVIT
    By agustnj.187972 in forum Revit Architecture - General
    Last Post: 2009-08-11, 12:17 AM
