Dear Vault users,
When working with Revit Server and Vault, the normal procedure to open a Revit working file is through Vault with proper authorization.
However, the same Revit file can also be opened directly from Revit Server by using Open command and selecting Revit Server as on the attached image. This second way to open the Revit file is NOT authorised.
Is there any solution under Vault to disable the possibility of accessing Revit files from Revit Server when Vault is installed?
Marcin Klocek
