Thread: Grading Criteria Sets
    2009-11
    Raleigh, NC
    937
    Default Grading Criteria Sets
    I am creating Civ3D templates for new company. I want to purge one of the two grading sets. I have done this before in settings under different feature menus by "Replace with" if it had the yellow triangle indicating it was in use then I simply deleted it. Grading Criteria sets seems to be a whole different headache. As shown in the image every style has the triangle. There are no grading objects in this file so is there some type of super purge to clean Civ3D files with?
    I really need to get this done so when others start using Civ3D I can have a one very simplified Grading Criteria Set.
    2004-06
    Slidell, Louisiana
    968
    Default Re: Grading Criteria Sets
    have you tried selecting the criteria and right clicking? i get a menu that has options, delete is one option. on the "set" with the triangle i think it will let you "replace with" the one without the triangle you should be able to delete.
    or you may have to delete each one individually and then the set.
    2008-03
    Columbia/Jefferson City, MO
    224
    you can purge Civil 3D styles (including the grading set criteria) by using the Purge button on the Styles panel of the Manage tab.
    2009-04
    71
    Hello tim_newsome if you want to know where this criteria is used you could use Find Reference command shown at contextual menu.
    See image below, this show you where is used or apply your criteria or style. So on references dialog box you could do double click and program show where you could change it.
    regards,
  1. 2015: Optimizing Corridor With Multiple Assemblies to Create Berm Based on Variable Grading Criteria
    By arander5343597 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2016-11-21, 10:04 PM
  2. CV214-3P: Subdivision Grading Made Easy: Grading Beyond the Roads
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-05-05, 03:27 AM
  3. Grading Style Criteria
    By jaldridge in forum AutoCAD Civil 3D - Grading
    Last Post: 2009-11-19, 11:55 PM
  4. Change the Grading Criteria of an Existing Grading
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-04-24, 07:22 PM
