Thread: Grading surface tries to attach to an alignment line when grading done first, why? How to fix?
    2016-04
    California
    150
    Question Grading surface tries to attach to an alignment line when grading done first, why? How to fix?
    Hello all,
    Why does placing an alignment line after a grading is completed mess up the grading? The two are not related at all in my drawing and this should not happen. I just wanted a surface profile of the FG and EG which requires an alignment first. See attached image.
    TT
    2008-03
    Columbia/Jefferson City, MO
    224
    Default Re: Grading surface tries to attach to an alignment line when grading done first, why? How to fix?
    Quote Originally Posted by tadthurston725387 View Post
    Make sure your alignment is NOT in the same site as your grading object.
    2016-04
    California
    150
    Thanks Mike,
    I discovered this too. Still makes me wonder why Autodesk set it up this way in the first place.
    TT
  1. 2016: Grading with PN_to Surface Errors
    By DreamDesignBuildRepeat in forum AutoCAD Civil 3D - Grading
    Last Post: 2016-02-17, 03:45 PM
  2. CV214-3P: Subdivision Grading Made Easy: Grading Beyond the Roads
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2013-05-05, 03:27 AM
  3. Grading to surface help
    By will.connolly in forum AutoCAD Civil 3D - Grading
    Last Post: 2012-08-14, 03:49 PM
  4. Change the Grading Criteria of an Existing Grading
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-04-24, 07:22 PM
  5. Site Surface & Grading Improvements
    By dazza163968596 in forum Revit Architecture - Wish List
    Last Post: 2004-11-19, 12:55 PM
Tags for this Thread
