Thread: Element Set Parameter Name
    2004-07
    206
    Default Element Set Parameter Name
    Hi Guys,
    I am started to learn Dynamo via available video tutorial. I have a question regarding the above Title (Subject) please refer to the attached image.
    Cheers
    Benjie
    2002-09
    Madison, WI
    5,688
    Default Re: Element Set Parameter Name
    This node is designed to set the Parameter value of an object by the Parameter name. So you need to feed a list of elements into the node, the parameter name you want to change, and the value or list of values you want to set.
  1. 2016: Retrieve element parameter by GUID
    By jabez706137 in forum Revit - API
    Last Post: 2017-10-16, 04:45 PM
  2. 2013 Search Set w NWC name & Element Parameter
    By brenehan in forum NavisWorks - General
    Last Post: 2012-12-29, 08:56 AM
  3. Element ID (as parameter value ?)
    By dante_van_wettum in forum Revit Structure - General
    Last Post: 2012-02-25, 02:36 PM
  4. Element ID as parameter
    By mui in forum Revit Architecture - General
    Last Post: 2011-10-14, 12:26 AM
  5. element.parameter overload-V8.1
    By GuyR in forum Revit - API
    Last Post: 2005-09-29, 03:19 PM
