We use spiral-curve-spiral transitions between tangents a lot. This includes s-curves where the alignment will diverge from a parallel line, then turn back to the original bearing but now farther away from that parallel line. I want to be able to control the length of the tangent between the S-C-S’s. If I just move the curves along the long tangents, trying to have the short tangent between the curves is like trying to hit a moving target. Is there a trick or setting or slight-of-hand to set the short tangent length?
