Thread: raise/lower a grading group
    2004-06
    Slidell, Louisiana
    939
    Default raise/lower a grading group
    what actually happens when you raise or lower a grading group. is it only raising or lowering by the amount you specify.
    i guess what i'm trying to figure out is what it actually changes, i.e. if you start with a feature line and grade to the bottom of a pond and create an infill, you can compute volume, correct?
    then if you raise or lower the group, what happens, does the infill go with it?
    i'm just a little confused.
    thanks
    2015-10
    Central New Jersey
    438
    Default Re: raise/lower a grading group
    In this instance I would raise/lower the feature line. The grading based on that feature line will update based on their grading properties. (ie: if they graded at a given slope to a pond bottom at a given elevation they will update to again grade at that slope to that elevation) Subsequent gradings and infills will update from there.
  1. 2015: Grading group incorporated in to Proposed surface
    By tim_newsome in forum AutoCAD Civil 3D - Grading
    Last Post: 2015-04-08, 05:57 PM
  2. Daylight Feature Line without using Grading Group
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-06-02, 04:58 PM
  3. Contact OP - Grading Group Elelvation Control
    Last Post: 2009-04-24, 02:14 PM
  4. How do you creat a surface from a grading group?
    By dorseydesignservices in forum AutoCAD Civil 3D - Grading
    Last Post: 2007-10-12, 05:23 PM
  5. Topo surfaces: seeing new grading that's lower than existing
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2004-03-09, 08:15 PM
