Thread: How do I tie-in a Civil 3D dwg to a 3D (CAD) but non Civil 3D dwg?
    2018-08
    3
    Default How do I tie-in a Civil 3D dwg to a 3D (CAD) but non Civil 3D dwg?
    I have a contour file, and a corridor of the same area of motorway (carriageway). I have received 3D information in CAD format (non Civil 3D format) and I now need to raise one channel up to tie into these new levels.
    What would be the best way of doing this - amending a previously created Corridor, creating a surface on the Contours dwg or doing it all from scratch?
    Civil 3D newbie, so be gentle.
    Cheers
    2020-12
    8
    Default Re: How do I tie-in a Civil 3D dwg to a 3D (CAD) but non Civil 3D dwg?
    First thing that you would have to do is create a Surface from those CAD format entities, I hope that you have received it in a proper format like 3D lines or normal lines with elevations for example. From there you can simply create your assembly you need and create the new channel when it is suppose to be.
  1. 2017: Export 2017 Civil 3d drawing with points and surface to 2014 Civil 3d
    By johnseg11 in forum AutoCAD Civil 3D - General
    Last Post: 2016-10-07, 04:17 PM
  2. 2016: Underpass Design in Civil Structures for Revit/ AutoCAD Civil 3D
    By MirandaO in forum Revit Structure - General
    Last Post: 2016-06-10, 09:34 AM
  3. 2014: Civil 3D 'shared reference point tool' and 'Integration with Civil 3D' revit extension problem?
    By alex.bell.252970 in forum Revit Structure - United Kingdom
    Last Post: 2013-11-26, 02:15 PM
  4. Replies: 0
    Last Post: 2013-04-17, 04:22 AM
  5. Se puede instalar civil 3D 2009 y civil 3D 2010 en un mismo Windows
    By wuari in forum AutoCAD Civil 3D - General
    Last Post: 2009-11-22, 03:27 AM
Tags for this Thread
