Results 1 to 9 of 9
Thread: Initial Drawing on AutoCAD 2005 Startup
    2005-02
    3
    Default Initial Drawing on AutoCAD 2005 Startup
    Is there any way to disable the opening of "Drawing1" when AutoCAD 2005 is launched. With older releases you used to be able to set the Initial Drawing setting to "." and it would not load a blank .dwg.
    Possibly a registry setting??
    Thanks!
    SM
    Jacksonville, FL
    13,656
    Default Re: Initial Drawing on AutoCAD 2005 Startup
    Hi
    Have a browse of the following thread -
    new drawing upon start-up..
    Have a browse of the following threads from the Autodesk Discussion Groups "AutoCAD 2005" -
    Start without opening a template
    Open Empty Autocad
    Have a good one, Mike
    18
    Quote Originally Posted by scott.commercial
    Thanks!
    SM
    Jacksonville, FL
    I have the same problem with ACAD2006. Did you have any luck finding the answer?
    13,656
    Question Re: Initial Drawing on AutoCAD 2005 Startup
    Quote Originally Posted by vpoon
    Hi
    Have you worked through the information found within the links given above ?
    18
    Quote Originally Posted by Mike.Perry
    Hi
    Yes, none of those helped. When you open ACAD2004 or older, you will see 'Drawing1' loaded by default. but when you open another file, it automatically close that drawing1 file. However, it is not the case in 2005 or 2006. What changed?
    thanks
    13,656
    Hi
    The information found in those links do answer the original question.
    With the above, you are now asking a slightly different question ( but a different question never-the-less ).
    As far as I am aware ( which means nothing ), the only way AutoCAD behaves as you now describe, is when SDI is set to 1 ( One ).
    Member girishpongalil's Avatar
    2005-08
    Dubai, UAE
    45
    I wrote this code in my acad.mnl and works fine .
    My Acad05 wont open any drawing with name "DRAWING1.dwg". So do not use this drawing name for any work.
    (if (= (STRCASE (SUBSTR (getvar "dwgname") 1 ) "DRAWING1") (command "close"))
    Note: SDI to be 0
    Earth
    9,802
    thanks
    Nothing changed with AutoCAD. What changed is that something in your startup is modifying "drawing1".
    When you open AutoCAD, immediately check the value of DBMOD. If it's not 0, then drawing1 stays open when you select another drawing.
    Of course if SDI=1, then you are prompted to save "drawing1"
    Find out what is modifying "drawing1" upon startup and get rid of it in your startup files.
    R.K. McSwain | CAD Panacea |
    18
    It turns out that the following 2 variables in my startup was affecting DBMOD.
    UCSFOLLOW
    ELEVATION
    Thanks to everyone for helping.
  1. Return to Initial Template Drawing Settings
    By Darren Allen in forum AutoLISP
    Last Post: 2014-05-07, 08:12 PM
  2. Replies: 1
    Last Post: 2008-10-11, 05:25 PM
  3. Cannot Recover drawing - AutoCAD 2005 file
    By CADKitty in forum AutoCAD General
    Last Post: 2006-10-03, 01:57 PM
  4. autocad 2000 lt drawing wont open in autocad mechanical 2005
    By garryh in forum AutoCAD Mechanical - General
    Last Post: 2005-06-21, 10:02 PM
  5. Startup problem with AutoCAD 2005
    By kfoley in forum AutoCAD General
    Last Post: 2005-01-19, 09:58 PM
