Results 1 to 1 of 1
Thread: 12 sided Solidworks object after import
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,073
    Default 12 sided Solidworks object after import
    Google has failed me on something I hope is simple...
    I have some parts from our head machinist that were done in Solidworks.
    When IMPorting into A2k19 and using any of realisitc, grey, etc views my 4" round object is shows as smooth wire and renders as 12 sided.
    It looks fine in Soldiworks and MasterCAM, but not so much in AutoCAD.
    Am I missing a simple variable that smooths the render of imported objects?
    Even the 3D objects I draw in the same drawing are smooth; it's only the imported Solidworks objects that are jagged.
    EDIT:
    Resolved: So after a couple hours searching, 45 minutes of playing with Solidworks settings, and 2 minutes of checking the block that was imported... I did a very, very simple thing that seemed to fix the problem. I exploded the block...
    (insert 3 minute profanity laden rant here)
  1. Import Failed when attempting to import Solidworks Model into AutoCAD
    By jgrabner in forum AutoCAD 3D (2007 and above)
    Last Post: 2016-03-29, 04:16 PM
  2. 2015: DWG Import Object Styles Issue (Not Working)
    By bart438099 in forum Revit - Platform
    Last Post: 2015-10-27, 07:07 PM
  3. ACA (ADT) object Import
    By envision.49524 in forum Revit Architecture - General
    Last Post: 2008-05-01, 04:29 PM
  4. 6 sided mass object
    By bob.86982 in forum Revit Architecture - Families
    Last Post: 2008-03-10, 03:03 PM
  5. Import Solidworks model into AutoCAD
    By Grumpy in forum Software
    Last Post: 2007-05-09, 06:30 PM
