Has anyone setup a tag that correctly uses the "structural abbreviations" for area reinforcement to display EF or EW?
I have a tilt panel that I'm detailing the rebar for. I have placed some area reinforcement where the Exterior Major Direction values are the same as the Interior Major Direction values.
I was just using the default tag that comes in the metric template which just displays the Summary and the result is:
N16 @ 400 (E)
N16 @ 400 (I)
I want it to display as N16 @ 400 EF
I thought adding the "Top and Bottom Major Layers Match" parameter to this label would do this, but instead it just follows the values above with a "Yes".
How do I get the Each Face or Each Way values to kick in?
Or doesn't it work in this circumstance...?
