RE: Top 10 We Like and Don't Like
• From: David Larrew (view other messages by this author)
• Date: Sat, 6 Sep 2003 17:40:47
Steve,
As ArchiCAD stands today (not in any order)...
CONS:
1. PlotMaker as a separate program.
2. Non-dockable toolbars and palettes.
3. Lack of (usable) macro language (Visual Basic, etc.).
4. Price.
5. Lack of TRUE single key commands.
6. The need for Loading of Libraries.
7. Lack of OLE integration (don't even try to count PlotMaker's attempt).
8. Handling of font's (please give me 1 Arial, 1 Helvetica, 1...).
9. Handling of printing output (too much to explain).
10. File size.
PROS:
1. Easy and fun to use.
2. Great project database capabilities.
3. GDL.
4. Teamwork.
5. "Virtual Building" method (single file).
6. Excellent export file translation (.DWG, .DWF, .DXF, etc.).
7. Use of vertical Stories.
8. Time and money saved during "CD" phase.
9. 2D and 3D integration.
10. It's not an Autodesk product (I hate monopolies).
David Larrew, AIA, GDLA
A r c h i S o l u t i o n s
www.archisolutions.com
• From: Eric Batte (view other messages by this author)
• Date: Sun, 7 Sep 2003 06:49:30
Steve,
Here's my list in no particular order.
Dont' like:
1. Cluttered user interface. The user experience is inconsistent
because of it. Check any office and you'll see palettes all over the
place. Everything is a floating window or palette and inherently has no
home.
2. Section/Elevation drawings aren't real-time and have limited
functionality (not all tools available in s/e)
3. PMKs! Yes, we now have linked views to the PLN, but they are still
PMKs published in the background. This prevents us from exporting DWGs
effectively from PlotMaker because PMKs are just dumb lines (no
objects, no dimensions, etc.). Likewise, because the PMKs must be
created by AC in the background this takes time but should be instant.
4. StairMaker. Inadequate for commercial steel stairs.
5. Scheduling. Current implementation of the Interactive Scheduler is
better than it has ever been, but still not good enough.
6. Everything should generate real-time, including sections,
elevations, 3D, schedules
7. Libraries. Difficult to manage and they must be "loaded" (whatever
that does). Loading entire libraries should not be needed (look at
Tiffeny and her 6000+ library parts!).
8. API is not free. This is deterring developers from developing
add-ons for ArchiCAD
9. Photorendering is completely below par for what we pay for.
10. No such thing as dimension or text "styles" that can be globally
defined
Like:
1. Teamwork
2. Working in AC feels more like being an architect than a draftsperson
3. Display options. Things like walls, doors, windows, etc. can be
displayed differently without drawing
4. PlotMaker. It has developed more into a true page layout application
that's very logical and easy to use.
5. GDL is the most useful, powerful and efficient programming language
and environment for CAD.
6. ArchiCAD is cross-platform which gives the users the choice of Mac
and/or Windows. Can't say that about anything from Autodesk.
7. Automatic drawing labeling (as in section/elevation/detail markers)
8. Excellent (perhaps the best) DWG compatibility from ArchiCAD. I've
heard that it's possibly better than Revit in DWG compatibility.
9. Publisher is a great tool for producing consistent output with one
or multiple users. For example it can be setup for producing DWG files
for all of you engineers and consultants with each one using different
versions of AutoCAD, layer settings, fonts, and saved to a different
folder. This must only be setup once in Publisher and subsequent DWG
exports are completely reliable, even from a novice.
10. Attribute manager let's you transfer attributes from one file to
another. Not perfect, but I haven't heard of a similar tool in otherCAD.
Eric Batte
RE: Top ten things we like and don't like
• From: Laurence (view other messages by this author)
• Date: Sun, 7 Sep 2003 18:10:44
Good topic!
Just a few to add
PROS - Where do I start!
1.I used to HATE dimensioning, now I love it and provide enough dimensions
to sink a ship and the builders love it! I would like, though, to be able
to click on the dimension and by changing it the elements connected would
adjust.
2.3D editing with all of the many options to make this task quick and easy -
the Marquee Tool, 3D Display Options, Select Image Items Options etc.
3.The many library parts available. Generally, excellent - the Revit rep
tried to convince me that "GDL was only there for people to make money out
of because in Revit we can model our own library part as we need it!" He
was very biased and not at all willing to actually listen so I was trying to
explain, so did not waste too much time there. Point in case - DoorBuilder
WindowBuilder is an excellent and well detailed tool I would be extremely
disappointed without it's availability. If you don't have it, you are
missing out!
4.All of my working drawings are in full colour with a 3D view on nearly
every sheet to assist builders/suppliers to read the drawings. I discovered
how to get colour directly off the model onto the elevations and sections
without cutting and pasting plus I switch on some shadows for depth.
Everybody but everybody loves the presentation and the readability of this
form, (I nearly wet myself when I discovered the colour directly off the
model secrete!) and could not stop looking at the finished drawings for a
week!
CONS
1.Rebuild in sections/elevations is a slow process, particularly as the
model grows. I understand Revit does not require this function. Is this what
'Real Time' is?
2.Not enough intelligence built into the whole Roof building/modelling
routine. I have seen VectorWorks create a gable end or dutch gable simply by
nominating that wall prior to an automatic insertion of the roof. In fact,
I now remember also seeing this on a well-written Australian add-on to
AuotCAD, DRC Auto, in that any number of different roof styles can be
nominated and defined before the automatic roof insertion.
3.As an extension to the above roofing situation, I saw about 12 years ago
another AutoCAD add-on, APDesign, the generation of the entire gang-nail
truss system so that ANY section view would be complete within the roof
structure. Yes, I did say about 12 years ago. This is where I spend most
of my time editing sections. For the record, the RoofMaker Accessory does
not come anywhere near what I saw in comparison to the trussed roof framing
routine.
4.The same lack of capability in regard to Slab-on-ground construction. I
don't understand why this has not been addressed (that I am aware of) to
trace the outline (or magic wand), input a few parameters, and bingo,
slab-on-ground! This needs to be editable on specific sides as well.
I see the two items above (2+3) as nuts and bolts stuff that can really
improve general productivity. Bells and whistles are great, but these are
two items that are without question on virtually every building we all
design. Wish list please!
5.The minor but annoying vertical / horizontal dimension option after you
click to position, always get I wrong when in a rush.
Got to get back to work and edit those sections / elevations!
That'll do pig. That'll do.
Kind regards, Laurence Brill
