Results 1 to 7 of 7
Thread: Overlap Point Position
    2006-05
    Tehran-IRAN
    23
    Default Overlap Point Position
    Hi everyone
    The FindSiteOverlaps command creates an AutoCAD point at the middle of the overlapping segments.
    I want those points to be at the start and endpoints of the overlapping segments.
    Thank you for attention.
    2004-06
    Slidell, Louisiana
    972
    Default Re: Overlap Point Position
    I'm not a 100% sure, but that looks like an internal C3D command and not a style that can be modified. might be able to it with a LISP routine, but i have no clue as to how to write that.
    2006-05
    Tehran-IRAN
    23
    Yes , This is possible
    marko_ribar did it https://forums.autodesk.com/t5/visua...s/td-p/8270644
    But I have a lot of alignments in different projects in civil 3d that, if done directly on them, is much better.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Your link is broken.
    2006-05
    Tehran-IRAN
    23
    2006-05
    Tehran-IRAN
    23
    No one is here to guide me.
    2002-01
    jUSt Here (a lot)
    9,103
    Quote Originally Posted by mrmonemi View Post
    You stated it was possible and provided a link to a solution. Does the solution not answer your problem?
  1. Overlap
    By srinivasarajug in forum AutoLISP
    Last Post: 2014-07-08, 03:53 PM
  2. vl-position not working on point list
    By tufofi in forum AutoLISP
    Last Post: 2012-01-20, 05:41 PM
  3. Overlap panel
    By tngv75955631 in forum Robot Structural Analysis
    Last Post: 2011-04-05, 11:13 PM
  4. wall overlap
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2010-10-21, 12:32 PM
  5. Line Overlap
    By mjdanowski in forum Revit MEP - General
    Last Post: 2007-03-29, 05:53 PM
