Thread: Non Destructive boundary
    2009-11
    Raleigh, NC
    944
    Default Non Destructive boundary
    How do I change the setting for a surface boundary so that the Non-destructive breakline box is not checked when I make a surface boundary?
    2015-12
    20
    3
    Default Re: Non Destructive boundary
    You can change that in the command settings. Go to the settings tab, then surface, then commands. Select "AddSurfaceBoundaries" and right click to select "edit command settings". Expand "Add Data Options" where you will find "Default non-destructive setting". Set it as desired.
    Zoeyanne
    C3D 2018
    2009-11
    Raleigh, NC
    944
    Thats what I needed. thanks.
  1. 2016: Boundary
    By tim_newsome in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2016-02-09, 08:36 PM
  2. 2015: corridor extents as outer boundary - shrinkwrap boundary
    By tott700763 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2015-09-15, 02:24 PM
  3. floor boundary by room boundary
    Last Post: 2012-12-13, 03:34 PM
  4. Replies: 0
    Last Post: 2012-03-29, 05:35 AM
