Thread: Shear stress formula on the glue between shaft and inner coupling
    2018-09
    Default Shear stress formula on the glue between shaft and inner coupling
    Hi,
    What would be the basic formula to work out shear stress in the glue joint between tube and coupling inside the tube.
    Tubular joint is special case of simple single lap shear in which tau=F/A. In that case area of joint will be pi()*D*length of insert.
    But how do I convert torsional load to normal load? Is it just torque/distance from centre of coupling?
    Regards,
    Stan
    Turlock, CA
    6,302
    Default Re: Shear stress formula on the glue between shaft and inner coupling
    You posted in the Raster Design forum. RD can't do what you're asking. What software are you using?
    C:> ED WORKING....
  1. 2013: Close-Coupling Families With Duct Connectors Sharing the Same Space
    By mrgrotey in forum Revit MEP - Families
    Last Post: 2017-06-27, 08:09 AM
  2. ROTATING COUPLING
    By kailashnkute488288 in forum Dot Net API
    Last Post: 2011-03-25, 11:21 AM
  3. Gasket thickness and grooved coupling gap
    By gmcnamee in forum AutoCAD General
    Last Post: 2010-01-29, 01:33 PM
  4. Pipework-ANSI socket welded coupling
    By landy90 in forum Dynamic Blocks - Sharing
    Last Post: 2008-03-22, 03:15 PM
Tags for this Thread
