Thread: Multi-leader landing line moves
    2018-10
    Default Multi-leader landing line moves
    When using a Multi-leader line that is not associated with any text (text was left blank) I have come across times when I move the leader line, the landing part only of the line moves to an askew angle. I then have to manually straighten the landing line.
    Is there a setting that needs addressed?
    9,720
    Default Re: Multi-leader landing line moves
    It sounds like you are drawing the horizontal part of the leader line (the "landing") instead of letting AutoCAD create it for you.
    Check the settings in your MLEADERSTYLE, on the "Leader Structure" tab.
    If you have "Maximum leader points" set to 2, and "Automatically include landing" checked ON, then when you create an MLEADER, you generally pick the arrowhead end, then pick the second point, and you're done.
    The horizontal part is the landing and it will never not be horizontal.
  1. 2013: leader landing extention
    By croejo594088 in forum AutoCAD General
    Last Post: 2013-02-27, 12:55 AM
  2. Leader landing
    Last Post: 2012-10-15, 06:11 PM
  3. multiple connection point for leader tails when using a multi-leader
    By jschraud228486 in forum AutoCAD Annotation
    Last Post: 2010-06-16, 01:42 AM
  4. Replies: 7
    Last Post: 2009-01-20, 10:32 PM
  5. mleader: text moves away from leader
    By pbrumberg in forum AutoCAD Annotation
    Last Post: 2008-04-11, 02:48 AM
