Thread: Surface Properties
    2009-11
    Raleigh, NC
    937
    Default Surface Properties
    Under the Analysis tab,
    Analysis type:
    What is the difference between Contours and Elevations?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,096
    Default Re: Surface Properties
    The analysis tab allows one to designate the display schema for each type. The display of these types is dependent on the assigned style for the surface. If the assigned style enables the elevations to be displayed, this schema will adjust the display dependent on the elevations of each triangle or face shown. The same will occur for contours if a schema is assigned.
    Another type of analysis could be user defined contour elevations. This is where that information is designated.
    2009-11
    Raleigh, NC
    937
    I get the overall concept there and you are right on my heels for the specifics of which I seek. Let me add the exact question now.
    If I change analysis type from Contours to Elevations the Ranges format changes. What do the ranges affect on a surface?
    It seems that I have seen Analysis type surfaces formatted as Contours used for the purpose of displaying contour lines. Analysis type formatted as Elevations used for the purpose of displaying ranges and aesthetics relative to ranges. is this an accurate assessment of the best practices of analysis types and finally,
    Is the best Analysis type for displaying contour lines "Contours"?
    2002-01
    jUSt Here (a lot)
    9,096
    Are you trying to show contours in differing colors based on the elevation of said contours? Then using the analysis for contours is what you are seeking. The style assigned to the surface must have the display of contours enabled.
    I have typically used the elevation banding to display these ranges. To make them more defined, I would also enable the display of contours in the same style, but would not provide an analysis of those contours.
  1. 2015: Civil 3D - System Variable - Object Viewer, Surface Properties etc
    By EarthShifter88 in forum AutoCAD Civil 3D - General
    Last Post: 2015-05-27, 02:51 PM
  2. Corridor properties: surface definition dialogue
    Last Post: 2014-11-14, 07:31 AM
  3. Surface Properties Toolbar
    Last Post: 2009-09-03, 10:04 PM
  4. Physical properties of Surface parts in Inventor
    By desaia in forum Inventor - General
    Last Post: 2008-05-16, 11:21 PM
