Thread: My polylining helper
    2001-12
    St. Louis
    5,313
    Default My polylining helper
    I haven't been doing plining for CAFM/IWMS usage for very long, but, I know how little I want to move once I get started on the clicks and picks.
    Does anyone else have any special setup for when they polyline their spaces?
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit and Tririga, too)
    Technical Editor
    2001-12
    St. Louis
    5,313
    Default Re: My polylining helper
    After a big project working the same type of files over and over, I made some modifications to my tool palette.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    in the upper right corner
    3,215
    That's pretty cool.
    I don't have the need to use polylines that extensively and I don't use tool palettes at all.
    How are those set up? Macros? Lisp?
    Most of what I do is on the command line, with either alias' to OOTB commands or lisp routines.
    Ted
    Windows 10
    2001-12
    St. Louis
    5,313
    That's pretty cool.
    The cleanup routines on there are lisp, just text for the osnaps I need but can't leave running on a busy drawing, regular command buttons for the rest.
    I usually use the commandline, too, but, when I've got a lot of repetitive work, I find it's easier to use one hand for the space bar and coffee and the other hand for all of the clicking and picking... chose the palette rather than a ribbon tab for being in the working space and autocollapsing.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Keyboard helper
    By andy.manninen in forum AutoCAD Tips & Tricks
    Last Post: 2007-11-22, 08:28 AM
  2. Multi-plane sweeps without helper objects
    By Wes Macaulay in forum Revit Architecture - Wish List
    Last Post: 2004-06-04, 04:20 PM
