Wall tags
Summary: Be able to select what wall type/ family to tag. Also, need to be in a coordination view in order to tag walls.
Description: Right now if you use tag all and select walls it will tag every wall. If walls do not have a tag then it shows up as ??. It would be nice to be able to select what walls can be tagged so that it is easier to tag all rated walls in the model. Or if possible to be smart enough to not place a tag on walls that do not have the tag parameter filled out. It would also be nice to not have to be in a coordination view for this to happen. An addition to this would be that if a wall type changes for the wall tag to automatically delete itself or update to new tag, not show up as ??.
Product and Feature: Revit MEP - Walls
Submitted By: bschneider737534 on 10/17/2018
- You may not post replies
- You may not edit your posts
Forum Rules
