Results 1 to 8 of 8
Thread: easy label a spiral if it's a pline?
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default easy label a spiral if it's a pline?
    I've been getting progress drawings from another consultant. I don't know what CAD they're using. The alignments are coming to me as lines and curves with polylines for the spirals. I can annotate the lines and curves quickly and easily. Is there a quick and easy way to label the plines with its length?
    2014-08
    447
    Default Re: easy label a spiral if it's a pline?
    Are we talking plines or splines. You can label a pline with the label dialog easily however be careful depending on accuracy desired the length may not be correct. A pline cannot represent a spiral and be listed with any great precision
    1,324
    Quote Originally Posted by remi678731 View Post
    Plines, not splines.
    2014-08
    447
    Hi
    This a new one to me I have heard of a pline used for a spiral except has been offset from centerline spiral which makes a pline of numerous short line segments. Is this not the case? I always thought plines were limited to line segments and simple curves that are connected into one object is this not the case?
    1,324
    Hi
    I received this from a source outside our offices. I suspect they used Microstation and somehow exported it to a DWG.
    That the plines are the spirals isn't as important to me. I'm looking for a way to label these plines with thier lengths.
    2014-08
    447
    Hi
    I wished I could help if it's not a spiral there is no way that I know of to correctly label it. You can label a spiral that is part of an alignment in the alignment label dialog. Can you ask the source for the spiral data.
    1,324
    Hi
    They have the geometric data on their drawing, but in a relatively small text that's unusable at a reasonable scale. For our purposes, we're mostly interested in the spiral lengths - in this case, the length of the pline.
    2014-08
    447
    I would copy their text to one of my layers and scale the text up to what I needed, or ask for and alignment landxml import alignment label the spiral.
  1. 2019: spiral-curve-spiral s-curve, set tangent to length?
    By Maverick91 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2018-07-27, 02:39 AM
  2. 2018: spiral-curve-spiral-curve-spiral-curve-spiral alignment?
    Last Post: 2018-06-07, 07:33 PM
  3. 2016: Spiral-curve-spiral 180 degree turn
    Last Post: 2016-01-15, 04:29 PM
  4. 2014: Error creating Spiral to Spiral
    By justinpickens77701535 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2015-06-03, 07:59 PM
  5. Adding spiral-curve-spiral between lines, like fillet?
    By Maverick91 in forum AutoCAD Civil 3D - General
    Last Post: 2011-08-12, 03:25 PM
Tags for this Thread
