Do you mean this post?
Computer Specs:
Renaming the xref works perfectly with preconfigured .las files. That's a great way to do it. I've put together a quick routine to import the .las and restore. Only hang up is manually needing to change the xref prior to applying the .las. What's the best way to automate the renaming portion of this? Each xref for the all projects will end with the last 4 characters being known: site, surv, util, grad etc. Is there a way to disregard the preceding project number and rename the xref? Below.
Project A
Site Plan
20201174-000-c-site => rename to => Site
20201174-000-c-surv => rename to => Survey
Project B
Site Plan
20201200-000-c-site => rename to => Site
20201200-000-c-surv => rename to => Survey
