Thread: Export Autocad 3D drawing into Google earth
    Default Export Autocad 3D drawing into Google earth
    I need help on how to get a kml file exported into google earth to be in the correct position. When I try exporting a drawing from autocad 3D to google earth, it does not fall in the right position, and I tried all tricks that I can but no way to get it right. Please help
    Default Re: Export Autocad 3D drawing into Google earth
    I assume you are using AutoCAD MAP 3D, since plain AutoCAD has no provision for this. For the export to work properly your drawing has to be assigned a coordinate system (see the ADESETCRDSYS command). Then it's also critical that your geometry has coordinates that lie within that assigned coordinate system. For example if your drawing system were LL84 (not likely) the coordinates would have to be from -180,-90 to 180,90 (lat/longs).
    You may have to check with the original creator of the drawing if it wasn't you, and you may have to enlist the help of a surveyor to transform your drawing. In summary, if it's assigned a system and your drawing coordinates are correct, your KML will hit correctly, otherwise there's not much chance of it.
    Thanks for the reply. I am using Autocad civil 3D. There is a function "Export KML" under Tools. It works well just that the drawing does not go in the right position. The drawing is from the Survey General Department. They assured me that in Autocad it is in the right position but then it moves away when I send it into google earth. I don't know what I am not doing right.
    TN/KY Area
    1,640
    Did you try the "ADESETCRDSYS" command to see if it has coordinate system assign to it? If you bring in an online map "GEOMAP" command does it some the image in the drawing correct?
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    2018-12
    4
    Quote Originally Posted by dotson View Post
    You may have to check with the original creator of the drawing if it wasn't you, and you may have to enlist the help of a surveyor to transform your drawing. In summary, if it's assigned a system and your drawing coordinates are correct, your KML will hit correctly, otherwise there's not much of it.
    Can this really be done? Wow. It seems so interesting to read the way you are describing it. Is there is reference page that I can use to understand more?
  1. Export to Google Earth, don't follow contours
    By Eric Stewart in forum Revit Architecture - General
    Last Post: 2012-03-08, 08:45 PM
  2. Google Earth Export - Include timeliner information
    By jobwallis724305 in forum NavisWorks - Wish List
    Last Post: 2011-08-01, 09:58 AM
  3. google earth connection - globe link vs google earth extension
    By rpict in forum Revit Architecture - General
    Last Post: 2010-06-21, 03:27 PM
  4. Google Earth Export Colors
    By jason.combs in forum Revit Architecture - General
    Last Post: 2008-04-15, 07:25 PM
