Quote Originally Posted by Razor View Post
Hi thanks for the reply,I add osmode 521 to give the option to snap on Endpoints, Node and Nearest at the End Point , but the snap is enabled but don't snap any ware in the drawing (for the end point). Why?
(grread) override object snapping
At the same time I don't understand your request, you fix a slope and you want to hang an object, isn't there a contradiction here? If you want to keep an introduced slope, the object snap is not recommended because it could necessarily modify the slope!
However if you want to consider osnap mode, see LeeMac's feature.
I let you adapt on your own because the request seems incongruous to me...
