Rotate cable trays
Summary: There should be to option to rotate a cable tray, so that you can show that it is placed on the wall. Right now there are some workarounds but it takes a lot of time and they are just that...workarounds.
Description: If it is needed to place a cable tray on a wall, right now you cannot rotate a cable tray. The function Rotate does not work. And it should because not all the cable trays are horizontally placed. And also, the cable tray fittings should also be adjustable to be placed on walls.
Product and Feature: Revit MEP - MEP Electrical Cable Tray - (Electrical)
Submitted By: tba.tofanbogdanandrei754949 on 11/02/2018
Re: Rotate cable trays
This wish has been reported by a member.
This thread is closed to further posts while the request is being reviewed by administrators.
- You may not post replies
- You may not edit your posts
Forum Rules
